NetApp Knowledge Base
CONTAP-309743: "metrocluster configure" command failing if key manager is configured on ONTAP 9.15.1
378
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
san
Last Updated:
Issue
  • metrocluster configure
     command cannot be run on ONTAP 9.15.1 if a key manager, onboard or external, is enabled.
  • This issue will prevent the expansion of existing MetroCluster clusters using new nodes running ONTAP 9.15.1 if the existing cluster is configured to use a key manager.
Example:
cluster_A::*> metrocluster configure
Error: command failed: MetroCluster cannot be configured while keymanager is configured on both partner sites. Disable
       keymanager on one of the partner sites and then proceed with MetroCluster configuration. After configuring
       MetroCluster, configure key manager on the partner site where it was disabled. If using the Onboard Key
       Manager, run the "security key-manager onboard sync" command on the partner site. Otherwise, if using external
       key manager, run the "security key-manager external enable" command on the partner site.
New to NetApp?
