NetApp Knowledge Base
SnapMirror Sync(SM-S) primary volumes has high latency due to volume bursty workload
1,137
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
  • ONTAP 9
  • SnapMirror Sync(SM-S)
Issue
  • The client reports very high write times on SM-sync primary volumes from SM-Sync from QOS command.
cluster::> qos statistics workload latency show -vserver SVM1 -volume vol1
Workload            ID    Latency    Network    Cluster       Data       Disk    QoS Max    QoS Min      NVRAM      Cloud  FlexCache    SM Sync         VA
vol1              4040    54.16ms    09.72ms        0ms    57.00us   14.00us         0ms     1.00us        0ms        0ms        0ms     44.44ms       0ms
vol1              4040    58.16ms    09.72ms        0ms    57.00us   14.00us         0ms     1.00us        0ms        0ms        0ms     48.44ms       0ms
  • The client may report  slow copy/write operation
$ time echo '123' >/cbsrun/test1.txt;time echo '123' >/cbsrun/test20220401/test2.txt;
real    0m1.08s
user    0m0.00s
sys     0m0.00s
real    0m3.26s
user    0m0.00s
sys     0m0.00s
  • An ESXI client may report Virtual machine disk write latency at Critical Level.
New to NetApp?
