NetApp Knowledge Base
Performance issue due to PCIE error
670
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
ONTAP 9
Issue
  • Slowness reported by an application hosted on NetApp LUN/Volume.
  • The latency is listed from the Network layer in the QOS statistics command output.
cluster::> qos statistics volume latency show -volume volume1 -vserver svm1
Workload        ID    Latency    Network    Cluster       Data       Disk        QoS      NVRAM      Cloud
volume1      17882     20.51ms    20.51ms      0ms        0ms        0ms        0ms        0ms        0ms
volume1      17882     15.00ms    15.00ms      0ms        0ms        0ms        0ms        0ms        0ms
volume1      17882     16.00ms    16.00ms      0ms        0ms        0ms        0ms        0ms        0ms
  • The RX/TX value of the FC port is well within the range.
  • No error is noticed in the switch logs.
  • The event log lists the PCIE error for one of the ports the host is logged into storage:
[Cluster1-01: PCI Link: pcie.stealth.link.errors:debug]: params: {'pcie_link_errors': 'performance is not optimal for PLX PCIE 8732 switch in slot 1 on Controller. Br[8732](4,0,0) in slot 1: LinkCap(MaxLkSp(3),MaxLkWd(16),ASPM(2),L0(6),L1(2),SurpDn,DLAct,Port(4)), LinkCap(MaxLkSp(3),MaxLkWd(16),ASPM(2),L0(6),L1(2),Port(0)), LinkStatus(LkSp(3),LkWd(2),DLAct).
New to NetApp?
