NetApp Knowledge Base
How to identify if workload is using indirect access
1,410
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
ONTAP 9
  • This article describes how to identify if traffic is indirect i/o.
  • Indirect i/o refers to the data LIF that users access being on a seperate node as the node with the disks the volume resides on.
  • This means the traffic must go through the Cluster Interconnect LIFs to be processed.
  • This can be important as it can cause performance degredations for some workloads, and is not supported for Cloud Volumes ONTAP.
