NetApp Knowledge Base
How to get full output of raw data with full precision and not SI prefixes in the statistics command
192
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
ONTAP 9
  • When using the statistics show -raw command, units may be in SI prefixes instead of fully precise.
  • Example: The below output shows Gigabytes (GB), not bytes:
Cluster::> set diag; statistics show -raw true -object aggregate -counter write_data -values *
Object: aggregate
Instance: aggr1
Start-time: 10/18/2023 12:00:37
End-time: 10/18/2023 12:00:37
Scope: node1
    Counter                                                     Value
    write_data                                                  974GB
New to NetApp?
