NetApp Knowledge Base
High latency from cluster interconnect caused by faulty SFPs/cable
765
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
ONTAP 9
Issue
  • Users reported high latency on NetApp volume.
  • Qos stats report latency from Cluster interconnect.
cluster1::> qos statistics volume latency show -iterations 100
Workload        ID      Latency     Network    Cluster    Data      Disk     QoS       NVRAM
-total-                2320.45ms   109.00us   2320.02ms  327.00us  32.00us    0ms        0ms
vdisk_vol1      111    2214.05ms   135.00us   2213.22ms  603.00us  89.00us    0ms        0ms
vol2            1234   2701.12ms   238.00us   2700.56ms  191.00us  133.00us   0ms        0ms
  • Depending on the type of SFP failure, this may not always trigger an EMS event
  • The EMS log may report the following error:
Mon Nov 21 08:31:41 +0900 [ST-BNC-5708N2: vifmgr: callhome.clus.net.degraded:alert]: Call home for CLUSTER NETWORK DEGRADED: Large MTU Packet Loss - Ping failures detected between cluster-02_clus2 ( xxx.xxx.xx.xx ) on Node2 and cluster-01_clus2 ( xxx.xxx.xxx.xxx ) on Node1
New to NetApp?
