NetApp Knowledge Base
High latency after ONTAP reboot due to malfunctioning Flash Cache
702
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
  • Fixed ONTAP version of Bug 1164008
    • ONTAP 9.3P9+
    • ONTAP 9.4P4+
    • ONTAP 9.5+
  • Flash Cache
Issue
High latency observed right after ONTAP reboot with the following symptoms:
  • Increasing disk util
  • Higher delay from Disk IO
  • No hits from Flash Cache (ext_cache). Example:
::> system node run -node node_name stats show -p flexscale-access
Cache                                               Reads         Writes          Disk Reads
Usage Hit   Meta  Miss    Hit  Evict  Inval  Insert Chain  Blocks Chain   Blocks  Replaced
%     /s    /s    /s      %     /s    /s     /s     /s     /s     /s      /s      /s
45    703   11    39171   1     0     0      0      0      0      0       0       109
45    320   26    37607   0     0     0      0      0      0      0       0        98
45    903   51    38018   2     0     0      0      0      0      0       0       114
  • The Flash Cache card status is ok in sysconfig -a
	slot 1: Flash Cache NVMe
		Serial Number:      ZEP00GPR
		Part Number:        119-00329
		Hardware Revision:  A0
		Firmware Version:   NA03
		Model Name:         X3311A
		Capacity:           1024 GB
		State:              ok
Notes:
  • This symptom is pretty close to what is described in Bug 1164008, though it's already on a fixed version.
New to NetApp?
