NetApp Knowledge Base
High disk latency with low IOPS in Azure CVO
770
Visibility:
Votes:
0
Category:
cloud-volumes-ontap-cvo
Specialty:
perf
Last Updated:
Applies to
  • ONTAP 9
  • CVO
  • Azure
Issue
  • The latency is seen from disk latency from QOS stats.
Cluster::> qos statistics volume latency show -vserver vs0 -volume vol0
Workload    ID    Latency    Network    Cluster       Data       Disk        QoS      NVRAM      Cloud
vol0      6762   137.73ms     1.91ms     1.00us    22.93ms   112.89ms        0ms        0ms        0ms
vol0      6762   133.29ms     1.82ms        0ms     2.84ms   128.62ms        0ms        0ms        0ms
vol0      6762    78.48ms     1.96ms        0ms     7.69ms    68.83ms        0ms        0ms        0ms
vol0      6762    50.51ms   239.00us        0ms   995.00us    49.28ms        0ms        0ms        0ms
  • The statit command indicates the IOPS are dropped while the disk utilization is increased.
disk             ut%  xfers  ureads--chain-usecs writes--chain-usecs cpreads-chain-usecs greads--chain-usecs gwrites-chain-usecs
/data_aggr1/plex0/rg0:
0a.00.18          100 280.18  280.18  64.00  67   0.00   ....     .  0.00   ....     .   0.00   ....     . 0.00   ....     .
0a.00.10          100 280.18  280.18  64.00  64   0.00   ....     .  0.00   ....     .   0.00   ....     . 0.00   ....     .
0a.00.19          100 280.18  280.18  64.00  71   0.00   ....     .  0.00   ....     .   0.00   ....     . 0.00   ....     .
0a.00.12          100 280.18  280.18  64.00  69   0.00   ....     .  0.00   ....     .   0.00   ....     . 0.00   ....     .
0a.00.17          100 280.18  280.18  64.00  75   0.00   ....     .  0.00   ....     .   0.00   ....     . 0.00   ....     .
0a.00.16          100 280.18  280.18  64.00  77   0.00   ....     .  0.00   ....     .   0.00   ....     . 0.00   ....     .
  • The Disk IOPS decreased from >3K to ~200, and disk utilization increased to 100% with 200_ pending, and queued IOPS.
  • EMS logs show connectivity errors as below
Tue Jul 16 14:47:05 +1000 [azpcvoause101c-01: pha_main000: scsi.cmd.floatTimeout:notice]: "Disk" device "0d.3L0": The page blob I/O operation timeout increased to "20" seconds: HA status "0x4": OSC Error "2": retry count "1": elapsed time "9712" milliseconds: cdb 0x88:00000000000272728820:0009. Disk 0d.3 S/N [sa82p4kn1zbcontainerotqmyqedc7iw] UID [sa82p4kn1zbcontainerotqmyqedc7iw] Target Address
New to NetApp?
