NetApp Knowledge Base
High Latency with SM-BC caused by network issues
1,690
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
  • ONTAP 9
  • SnapMirror Active Sync (SM-AS)/SnapMirror Business Continuity (SM-BC)
Issue
  • High latency reported from SnapMirror Sync
    • SM-AS/SM-BC relies on SnapMirror Sync (SM-S)
    • CLI command qos statistics workload latency show shows the high latency from SM Sync
    • AIQUM/OCUM shows the high latency from Sync SnapMirror
  • EMS errors are logged on the primary site:
Tue Apr 04 02:38:22 +0800 [Node1-01: repl_Handle_sync_resl: callhome.syncsm.exception:error]: Call home for SNAPMIRROR SYNCHRONOUS EXCEPTION: Network Latency exceeded threshold limit.
  • CLI command network test-link shows a high network latency between the source and destination cluster
New to NetApp?
