NetApp Knowledge Base
High CPU utilization on a Snapmirror Destination Node
845
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
Perf
Last Updated:
Applies to
  • ONTAP 9
  • Snapmirror DP relationships
Issue
  • Latency is seen when high CPU utilization occurs due to Snapmirror job in progress.
  • The top workloads for D blade utlization was WAFL SCAN, wafl cp , WAFL and snapmirror as per perf archive graphs.
  • Output of wafl scan status   shows  scanners like snap create summary update; block ownership calculation and volume deswizzling ( which is for snapmirror) scans happening.
  • Since this is the destination for snapmirror, so these scanners are expected.
::>system node run -node * -command wafl scan status
Node: xxxx
Volume xxx:
 Scan id                   Type of scan     progress
  603754     snap create summary update     block 496578 of 676206
  604189    block ownership calculation     block 469500 of 676205
Volume xxy:
  604343     snap create summary update     block 6452 of 45690
  604265     blocks used summary update     block 24304 of 45690
Volume abc:
  604291     snap create summary update     block 7689 of 59397
  604234     blocks used summary update     block 13233 of 59397
      55             volume deswizzling     snap 366, inode 183826 of 33554416. level 1 of normal files. Totals: Normal files: L1:1798785/3219086468 L2:6755/3234086207 L3:3369/1298071658 L4:0/0      Inode file: L0:0/0 L1:0/0 L2:0/0 L3:0/0 L4:0/0
New to NetApp?
