CONTAP-832089: ONTAP 9.19.1 QoS ratebucket limit_rate stuck at 1 and does not rebalance across nodes
Issue
- High workload latency and throttling during QoS enforcement windows
- Removing the affected QoS policy from volumes restores normal performance
- One node retains nearly the full QoS limit while another active node remains constrained at limit_rate 1
- QoS ratebucket limit_rate drops to 1 on an active node and does not rebalance back to the node handling most of the workload
