NetApp Knowledge Base
Volume Moves Fail with “Volume is not quiesced”
78
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
  • ONTAP 9
  • AFF/ASA/FAS
  • Environments with NFS workloads and deduplication enabled
Issue
  • Volume move operations fail to complete, with repeated errors such as:
[Node1:mgwd:mgmt.vopl.move.cutover.failed:error]: The volume move operation with ID '4684' on volume 'vol_01' on Vserver 'svm_01' to destination aggregate 'aggr1' did not cutover because: 'Volume is not quiesced'. The volume move operation has tried to cutover '3' out of '3' times, 0 forced.
[Node1:mgwd:mgmt.vopl.move.cut.entryFail:error]: The volume move operation of volume 'vol_01' in Vserver 'svm_01' to destination aggregate 'aggr1' did not enter the cutover phase. The system provided the additional explanation: 'Preparing source volume for cutover: Deduplication is not ready for volmove cutover'. After a short delay, the volume move operation will reattempt cutover entry.
  • Additional symptoms:
    • Volume move jobs remain in the “replicating” phase at 98% indefinitely.
    • Multiple FlexGroup constituents fail with the same error.
    • Cluster shows high CPU utilization during multiple concurrent volume moves.
New to NetApp?
