Is it possible to use a specific encryption key for a specific volume
Applies to
- ONTAP 9
- NetApp Volume Encryption (NVE)
Answer
- You cannot specify a key for the volume. When creating an encrypted volume or enabling encryption on a volume ONTAP will assign a unique key to the volume.
- You can change the encryption key with a rekey, but you do not specify a key.
