Ifgrp interface generates vifmgr.cluscheck.hwerrors during high load
Applies to
- 9.10.1P12 and earlier
- 9.11.1P9 and earlier
- 9.12.1P3 and earlier
- Interface Group (ifgrp)
- Virtual Lan (VLAN)
Issue
- EMS logs:
[Node-01: vifmgr: vifmgr.cluscheck.hwerrors:alert]: Port a0a on node Node-01 is reporting a high number (at least 1 per 1000 packets) of observed hardware errors (CRC, length, alignment, dropped).
[Node-01: vifmgr: vifmgr.cluscheck.hwerrors:alert]: Port a0a-114 on node Node-01 is reporting a high number (at least 1 per 1000 packets) of observed hardware errors (CRC, length, alignment, dropped)
- Only IFGRP TRANSMIT Total errors values increase, physical port in IFGRP shows no errors
-- interface a0a-114 (3 days, 3 hours, 47 minutes, 23 seconds) --
RECEIVE
Total frames: 72688k | Frames/second: 266 | Total bytes: 207g
Bytes/second: 760k | Total errors: 0 | Errors/minute: 0
Total discards: 0 | Discards/minute: 0 | Multi/broadcast: 17569
Non-primary u/c: 0 | Errored frames: 0 | Unsupported Op: 0
CRC errors: 0 | Runt frames: 0 | Fragment: 0
Long frames: 0 | Jabber: 0 | Length errors: 0
Alignment errors: 0 | No buffer: 0 | Xon: 0
Xoff: 0 | Pause: 0 | Jumbo: 0
Noproto: 0 | Error symbol: 0 | Illegal symbol: 0
Bus overruns: 0 | Queue drops: 0 | LRO segments: 0
LRO bytes: 0 | LRO6 segments: 0 | LRO6 bytes: 0
Bad UDP cksum: 0 | Bad UDP6 cksum: 0 | Bad TCP cksum: 0
Bad TCP6 cksum: 0 | Mcast v6 solicit: 0 | Lagg errors: 0
Lacp errors: 0 | Lacp PDU errors: 0
TRANSMIT
Total frames: 72934k | Frames/second: 267 | Total bytes: 410g
Bytes/second: 1503k | Total errors: 52183 | Errors/minute: 11
Total discards: 0 | Queue overflow: 0 | Multi/broadcast: 9861
Collisions: 0 | Max collisions: 0 | Single collision: 0
Multi collisions: 0 | Late collisions: 0 | Xon: 0
Cfg Up to Downs: 0 | TSO non-TCP drop: 0 | Split hdr drop: 0
Timeout: 0 | TSO segments: 11263k | TSO bytes: 396g
TSO6 segments: 0 | TSO6 bytes: 0 | HW UDP cksums: 0
HW UDP6 cksums: 0 | HW TCP cksums: 0 | HW TCP6 cksums: 0
Mcast v6 solicit: 0 | Lagg drops: 0 | Lagg no buffer: 0
Lagg no entries: 0
DEVICE
Mcast addresses: 1 | Rx MBuf Sz: 0
LINK INFO
Speed: n/a | Duplex: n/a | Flowcontrol: n/a
Media state: active | Up to downs: 1 | HW assist: 5655
