NetApp Knowledge Base
How to patch Java JRE versions for older SANtricity Management Plug-ins and APIs
523
Visibility:
Votes:
1
Category:
e-series-santricity-management-plug-ins
Specialty:
esg
Last Updated:
Applies to
  • SANtricity
  • NetApp - Patch for Updating Java Runtime Environment (JRE) used by the applications Web server.
  • NetApp SANtricity Plug-in for VMware vCenter
  • NetApp SANtricity Management Pack for Microsoft System Center Operations Manager
  • NetApp SANtricity Web Services Proxy
  • NetApp SANtricity Storage Replication Adapter
  • NetApp SANtricity VASA Provider
  • NetApp E-Series Plug-In for VMware vCenter 2.7
  •  NetApp SCOM Integration Pack 2.1
  •  NetApp SANtricity Web Services Proxy 1.1
  •  NetApp Storage Replication Adapter for E-Series 5.5
  •  NetApp VASA Provider for E-Series 5.5
This article describes the procedure  on how to patch Java JRE versions for older SANtricity Management Plug-ins and APIs.
This script allows the user to change the JRE version used to run the Web server from the pre-installed version to a more recent one.
The script can be found at the following location on the NetApp Support Site:
SANtricity Management Plug-ins - 1.0J
New JREs can be downloaded from Oracle at the following link and installed as documented.
Java SE Downloads
New to NetApp?
