SnapCenter remote clone operation across ESX hosts fail with error "Failed to Map virtual disk: Invalid datastore path"
Applies to
SnapCenter Plugin for Windows (SCW)
Issue
SnapCenter remote restore or clone operation across ESXi hosts fail with error "Failed to Map virtual disk: Invalid datastore path".
The error can be found in the SMCore.log and VirtualizationAPI.log on the destination Windows host:
ErrorMessage (An error occured while cloning RDM based disk. Failed to Map virtual disk: Invalid datastore path '[SQL_DBs] SQL2/SQL2_SD_svm1.demo.netapp.com_wOj5-?JhN8Op_2.vmdk'. Error: Failed to map virtual disk on Esx host after retrying.)
