NetApp Knowledge Base
Unable to add a Plug-In Host to SnapCenter
3,375
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Server (SC)
  • SnapCenter Plugin for Windows (SCW)
  • User Access Control (UAC)
  • User account being used is a local user of the Host, member of the Administrators group but user is not called "Administrator"
Issue
SC fails to add a plugin host and reports the following error message:
The host  is not accessible with the specified credentials. You must ensure that the following conditions are met:
  • The credential has administrator privileges for the plug-in host.Elevated privileges are required for local user accounts.
  • The required ports are open between SnapCenter Server and the plug-in host if the firewall is enabled. For more information on ports, see SnapCenter Installation and Setup Guide.
New to NetApp?
