NetApp Knowledge Base
SnapCenter backup cataloging failure with ORA 02290 check constraint violation
197
Visibility:
Votes:
0
Category:
snapmanager-for-oracle
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter Plug-in for Oracle (SCO) version 6.0
  • Oracle Database version 19c
Issue
  • Backup cataloging fails for the database with:
com.netapp.oracle.core.exception.OracleCoreException: ORACLE-00101: Error executing RMAN command: [CATALOG START WITH '/var/opt/snapcenter/sco/backup_mount/<DATABASE_NAME>_<INSTANCE_NAME>_<TIMESTAMP>/archivelog/' NOPROMPT;]. The command returned: RMAN-00571: ===========================================================
RMAN-00569: =============== ERROR MESSAGE STACK FOLLOWS ===============
RMAN-03002: failure of catalog command at <DATE> <TIME>
RMAN-03014: implicit resync of recovery catalog failed
RMAN-03009: failure of partial resync command on default channel at <DATE> <TIME>
ORA-02290: check constraint (RMAN19C.BP_C_COPYNO) violated
  • MAN user privileges: Granted to SYSBACKUP privileges
  • SQL Query Result:
    • GRANTEE: SYSBACKUP
    • GRANTED_ROLE: SYSBACKUP, SELECT_CATALOG_ROLE
    • ADM DEL DEF COM INH: NO NO YES NO NO
New to NetApp?
