NetApp Knowledge Base
SnapCenter SQL backups are failing with "Error:The referenced account is currently locked out and may not be logged on to"
279
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Server 4.x
  • SnapCenter Plug-in for SQL 4.x
Issue
SnapCenter SQL backups are failing with "Error:The referenced account is currently locked out and may not be logged on to".
SnapCenter SMSQL Log:
ERROR SmSql_306130 PID=[9132] TID=[42] ConnectionFailureException: The referenced account is currently locked out and may not be logged on to.
ERROR SmSql_306130 PID=[9132] TID=[42] ErrorCode (-1), ErrorMessage (The SQL instance 'Database Instance name' is either stopped or the user 'User name' does not have required permission. Error: The referenced account is currently locked out and may not be logged on to.)
ERROR SmSql_306130 PID=[9132] TID=[42] The SQL instance 'Database Instance name' is either stopped or the user 'user name' does not have required permission. Error: The referenced account is currently locked out and may not be logged on to.
ERROR SmSql_306130 PID=[9132] TID=[42] Failed to enumerate SQL Server instance {Database Instance name}
ERROR SmSql_306130 PID=[9132] TID=[310] ErrorCode (0), ErrorMessage (Discovery of SQL Instances 'Database Instance name' failed. Ensure the SQL server(s) are in running state with sysadmin privileges.)
New to NetApp?
