NetApp Knowledge Base
SnapCenter Oracle backup fail with error PL-SCO-20054: %1$s is not a Cluster Database
101
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter 4.x
  • SnapCenter plug-in for Oracle (SCO) 4.x
  • Oracle Real time Application Cluster (RAC)
Issue
SnapCenter Oracle backup fail with error:
ERROR SnapManagerWeb_185573 PID=[2068] TID=[3] ErrorCode (-1), ErrorMessage (PL-SCO-20046: Validate prefer host operation for SnapCenter Plug-in for Oracle Database failed for database <DB_name> on host <hostname> with error PL-SCO-20054: %1$s is not a Cluster Database)
SPL Log:
DEBUG Execution Monitor Thread [export  SC_PWD=/opt/NetApp/snapcenter/spl/lib  PATH=/oracle/app/oracle/19C/dbhome_1/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin  ORACLE_SID=<DB_name>  ORACLE_HOME=/oracle/app/oracle/19C/dbhome_1 ; export LC_ALL=C; srvctl config database -d <DB_name>] c.n.c.e.ShellResult - EXE-00001: Shell result [0:00:05.172] (Exit Value: 1):
PRCD-1120 : The resource for database dssuats could not be found.
PRCR-1001 : Resource ora.dssuats.db does not exist
DEBUG   VlPHst-<DB_name> c.n.o.c.s.d.c.ClusterDatabaseService - Could not determine the RAC type of the database
DEBUG   VlPHst-<DB_name> c.n.o.c.s.d.c.ClusterDatabaseService - Completed method  isClusterDatabaseNode within 5.817052 seconds.
ERROR   VlPHst-<DB_name> c.n.p.s.u.OraclePluginUtil - PL-SCO-20046: Validate prefer host operation for SnapCenter Plug-in for Oracle Database failed for database <DB_name> on host <hostname> with error PL-SCO-20054: %1$s is not a Cluster Database
com.netapp.sco.smcore.plugin.exception.PluginExecutionFailedException: PL-SCO-20054: %1$s is not a Cluster Database
New to NetApp?
