NetApp Knowledge Base
Secure DB connection for SAP Hana Backups
350
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
SnapCenter Plugin for SAP HANA (SCHANA)
Issue
When adding extra SSL parameters to SAP hana hdbsql the backup will fail with the following errors:
This command fails with error: [/hana/shared/HEA/hdbclient/hdbsql -U HEABACKUP -e -sslprovider commoncrypto -sslkeystore /usr/sap/HEA/HDB20/hdb20hea-001/sec/sapsrv.pse -ssltruststore /usr/sap/HEA/HDB20/hdb20hea-001/sec/sapsrv.pse -sslhostnameincert hvm034: Command not found.].
 Set valid HDBSQL_CMD for the SAP HANA plug-in on this host using "Set-SmConfigSettings -Plugin -HostName hostname -PluginCode hana ?configSettings @{"HANA_HDBSQL_CMD"="path_to_HDBSQL_CMD"} " PowerShell cmdlet from SnapCenter Server.
[2020-03-20 13:12:56,017] ERROR:
[10.1.54.120:9090(4.3.0.0)] SCF-00037: Application quiesce for plug-in [hana] failed with error [] and exit code [1], Exiting!
New to NetApp?
