NetApp Knowledge Base
SCV 5.0P1 retention issue in SM-BC setup
682
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter plugin for VMware (SCV) 5.0x
  • SnapMirror Active Sync (SMBC), also known as SnapMirror Business Continuity
Issue
  • When SM-BC is configured, SCV fails to delete certain snapshots at the end of backup jobs as per the retention settings.
  • While backup references are removed from the SCV repository, snapshots remain on storage.
  • These undeleted snapshots are usually flagged in ASUP with the following message:
Snapshot copy 'snaphost_name' is not successfully replicated for the relationship 'xxxxx-xxxx-xxxx' with source volume DSID 'xxxx' and path '/vol/volpath'. Reason: Failed to write metadata information to source volume snapshot
Potential Consequences
  • Storage Consumption: Space issues on source or destination aggregates due to the accumulation of Automated Cloud Sync (ACS) snapshots.
  • SMBC Out of Sync: SnapMirror Business Continuity (SMBC) setups may go Out of Sync if volumes or aggregates run out of space.
New to NetApp?
