NetApp Knowledge Base
SCV4.8+ maintenance console shows "Setting locale failed" after upgrade
270
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Plug-in for VMware vSphere (SCV)
  • After upgrading SCV to 4.8 or later
Issue
When logging into Maintenance Console of SCV, the following warnings are displayed:
 Maintenance Console : "SnapCenter Plug-in for VMware vSphere"
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
        LANGUAGE = (unset),
        LC_ALL = "en_US.UTF-8",
        LANG = (unset)
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
        LANGUAGE = (unset),
        LANG = (unset)
        LANGUAGE = (unset),
        LANG = (unset)
 Discovered interfaces: eth0 (ENABLED)
 Main Menu:
    1 ) Application Configuration
    2 ) System Configuration
    3 ) Network Configuration
    4 ) Support and Diagnostics
    x ) Exit
 Enter your choice:
New to NetApp?
