NetApp Knowledge Base
SCSQL log backup fails due to insufficient space: System.Data.SqlClient.SqlError: Write on "PATH.TRB" failed: 112 There is not enough space on the disk
139
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
SnapCenter plugin for SQL
Issue
Backup of <RG> using policy <Policy> on <Host> failed with error: Failed on 'XYZ':
Activity 'Begin Transaction Log backup' failed with error: Resource (Database) failed with error (System.Data.SqlClient.SqlError: Write on "<PATH>.TRB" failed: 112(There is not enough space on the disk.)).
Logs:
DEBUG SmSql_414136 PID=[5372] TID=[94] 70 percent processed.
DEBUG SmSql_414136 PID=[5372] TID=[94] Backup of database [EFTDB81] percentage of completion : 80...
DEBUG SmSql_414136 PID=[5372] TID=[94] 80 percent processed.
ERROR SmSql_414136 PID=[5372] TID=[94] System.Data.SqlClient.SqlError: Write on "<path>.TRB" failed: 112(There is not enough space on the disk.)
ERROR SmSql_414136 PID=[5372] TID=[94] ErrorCode (-1), ErrorMessage (System.Data.SqlClient.SqlError: Write on "<path>.TRB" failed: 112(There is not enough space on the disk.))
New to NetApp?
