NetApp Knowledge Base
SCO Backup Cataloging fails
458
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
SnapCenter Plug-In for Oracle 4.5 (SCO)
Issue
SCO Backup Cataloging fails with the below RMAN error:
2022-05-06T14:58:06.6351650+02:00 DEBUG SnapManagerWeb_5 PID=[6001] TID=[02] Updating the job (5) task (Cataloging Backup) status as Failed
2022-05-06T14:58:06.5726622+02:00 ERROR SMCore_5 PID=[4001] TID=[01] ErrorCode (-1), ErrorMessage (Cataloging backup failed for ORA1 with below error. For complete error refer logs.
com.netapp.oracle.core.exception.OracleCoreException:
ORACLE-00101: Error executing RMAN command:
[CATALOG DATAFILECOPY ' var opt snapcenter sco backup_mount oracledb-test_test-db01_05-06-2022_14.49.02.6910_0 ORA1 1 oradata ORA1 AAAABBBB0000CCCC1111DDDDAAAAA2A2 datafile ...
The command returned: RMAN-00571:
RMAN-00569:
=============== ERROR MESSAGE STACK FOLLOWS ===============
RMAN-00571:
RMAN-03009: failure of catalog command on default channel at 05 06 2022 14:58:04ORA-19564: error occurred writing 8192 bytes at block number 1
ORA-27091: unable to queue I O
ORA-27041: unable to open file
2022-05-06T14:58:06.5882871+02:00 DEBUG SMCore_5 PID=[4001] TID=[01] [Cataloging] Cataloging backup failed for ORA1 with below error. For complete error refer logs.
New to NetApp?
