NetApp Knowledge Base
RabbitMQ installation fails during Snapcenter upgrade
391
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • Snapcenter 5.X
  • Snapcenter 6.X
  • RabbitMQ
Issue
  • During the upgrade we see the following errors during the RABBITMQ installation:
    Executing command: rabbitmq-plugins.bat enable rabbitmq_management
    4-12-2026[01:22:12 PM]: (PowerShell Action): rabbitmq-plugins.bat output:
    13:22:04.925 [error] Failed to create cookie file 'p:/.erlang.cookie': enoent
    13:22:05.691 [error] Failed to create cookie file 'p:/.erlang.cookie': enoent
    13:22:06.394 [error] Failed to create cookie file 'p:/.erlang.cookie': enoent
    13:22:06.410 [error] Failed to create cookie file 'p:/.erlang.cookie': enoent
    13:22:07.191 [error] Failed to create cookie file 'p:/.erlang.cookie': enoent
  • After the upgrade we see the following error in the Snapcenter GUI
    Alert Name RabbitMQ Connection Failure
    Severity  Critical
    Entity Type SnapCenter Server
    Entity Name SC.Demo.net
    Status New
    Time 04/12/2026 12:34:06 PM
    Job Id Not applicable
    Description SnapCenter Server is unable to establish RabbitMQ connection
    Recommendation Verify and ensure RabbitMQ service is running. If problem persists, reach out to SnapCenter support
New to NetApp?
