NetApp Knowledge Base
MaxDB backup fails with quiesce error after upgrading JAVA
114
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter Custom Plug-in for MaxDB 1.0
  • SnapCenter Plug-in for Windows (SCW) 5.0P2 and earlier
  • JAVA 11
Issue
After upgrading JAVA on the MaxDB plug-in host, from 1.8 to 11, backups of MaxDB resources start failing with the following errors seen:
SnapCenter UI:
Quiesce Filesystem failed with Exception: null
MaxDB_<JobID_Date_Time>.log:
ERROR  [pool-7-thread-5] 195 com.netapp.plugincreator.workflow.impl.SCTaskCallableBlocking -Exception thrown by task:quiesceFS with config:<Profile>@<Resource_Group>
ERROR  [pool-7-thread-5] 195 com.netapp.plugincreator.workflow.impl.SCTaskCallableBlocking -Task: quiesceFS with config:<Profile>@<Resource_Group> failed
ERROR  [pool-7-thread-8] 189 com.netapp.plugincreator.workflow.util.TaskUtil -Could not execute operation metadataCleanup on plugin MAXDB (Reason: NullPointerException: )
ERROR  [pool-7-thread-8] 270 com.netapp.plugincreator.workflow.Task -Could not execute operation metadataCleanup on plugin MAXDB (Reason: NullPointerException: )
New to NetApp?
