NetApp Knowledge Base
How to use Swagger to edit configuration parameters in SCV
9,142
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
SnapCenter Plugin for VMware (SCV) 5.x and higher
  • Multiple configuration parameters in SCV can be changed to match the needs of a specific environment.
  • Starting in SCV 6.x  and later, the recommended way to adjust these is via internal SCV RestAPI using Swagger UI.
Note: If the UseAppSettings is set to True in the SCV/opt/netapp/protectionservice/publish/storage/appsettings-storage.json file, this will override the Swagger configuration. If using Swagger, set the UseAppSettings parameter to False and restart SCV services.
New to NetApp?
