NetApp Knowledge Base
How to make the host as soft deleted in SnapCenter?
370
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
SnapCenter having a registered host with protected databases
  • This KB provides a way remove the added host temporarily from SnapCenter view without having to delete associated backups.
  • This can be used when you want to do a host refresh or do some downtime activities on the host for a shorter period of time.
  • As part of this alternative procedure, the KB explains how to:
    • Make the host as soft deleted
    • Add soft deleted host back
    • Remove soft deleted host permanently, in case it is needed
New to NetApp?
