NetApp Knowledge Base
How to Remove the SnapCenter Plugin for VMWare
82
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Plug-in for VMWare (SCV)
If you no longer need to use the SnapCenter data protection features, you must disable the SnapCenter Plug-in for VMware vSphere to unregister it from vCenter, then remove the SnapCenter Plug-in for VMware vSphere from vCenter, and then manually delete leftover files.
New to NetApp?
