NetApp Knowledge Base
Does SnapCenter support Java 9, 10 or 11?
2,658
Visibility:
Votes:
1
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Plug-in for Unix (SCU) with Linux
  • SnapCenter Plug-in for Oracle (SCO) with Linux
  • SnapCenter Plug-in for SAP HANA (SCHANA)
  • Java (Oracle and OpenJDK) 64-bit
Answer
Java versions supported and compatible with SnapCenter
  • SnapCenter 4.0 - 4.7
    • Java 1.8 (64-bit)
  • SnapCenter 4.8 - 5.0
    • Java 1.8 (64-bit)
    • Java  11 (64-bit)
  • SnapCenter 6.0 to 6.1
    • Java 11 (64-bit)
Note: Please use the above mentioned Java version, as this has been thoroughly tested and qualified to ensure it works as expected, support for the most recent Java release will be included in future Snapcenter releases.
Additional Information
Under Linux we support both the official OpenJDK 11 as well as Oracle Java 11 (rpm installation as root) as separate updates from the O/S support.
Java 17 support is being validated
For up-to-date information, please contact NetApp Support.
From SnapCenter 4.4 onwards, the AIX support is limited to the SCO (and SCU) Plug-in with SAN, and uses IBM AIX's own Java implementations, it should be equivalent to these version requirements.
