NetApp Knowledge Base
Connection loss between SnapCenter Plug-in and the SnapCenter Server with routed paths
2,092
Visibility:
Votes:
1
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Server
  • SnapCenter Plug-in for SQL (SCSQL)
  • SnapCenter Plug-in for Exchange (SCE)
  • SnapCenter Plug-in for Oracle (SCO)
Issue
Randomly, the connection appears to be severed after some time, causing updates back to the SnapCenter Server to be missed, for example from SMCore log:
DEBUG SMCore_<JOB> PID=[<Process>] TID=[<Thread>] RemoteUrl: https://<SNAPCENTER_FQDN>:8146/BackupService.svc/DeleteBackup
ERROR SMCore_<JOB> PID=[<Process>] TID=[<Thread>] WebException Encountered, Response null
ERROR SMCore_<JOB> PID=[<Process>] TID=[<Thread>] Exception in method: Invoke.
System.Net.WebException: The underlying connection was closed: A connection that was expected to be kept alive was
closed by the server. ---> System.IO.IOException: Unable to read data from the transport connection:
An existing connection was forcibly closed by the remote host. ---> System.Net.Sockets.SocketException:
   at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size)
The (in this case a backup deletion) request was sent, but the connection was severed after a little over two minutes.
This can be seen from time stamps on the "RemoteURL" line to the next line with the "Exception in method".
Another error that can be seen, for example in the Details View of a still "Running" verification job would be:
The underlying connection was closed: An unexpected error occurred on a receive.
New to NetApp?
