NetApp Knowledge Base
Hitachi OPs Center data source addition fails with 401 Unauthorized in OCI
385
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
om
Last Updated:
Applies to
  • OnCommand Insight (OCI) 7.3.12+
  • Hitachi HDS Ops Center
Issue
  • Hitachi OPs Center data source addition  fails with 401 Unauthorized in OCI in the test credential step
  • acq.log:
ERROR [DSM-pool-3-thread-92/<opscenter_name>(test)] com.onaro.sanscreen.acquisition.datasource.hds_opscenter.OpsCenterFoundationPackage (OpsCenterFoundationPackage.java:84) - Failed to execute test command on device: Unable to login to the device. Error message received from device is : Request failed with status 401 : https://<opscenter_name>:20961/v1/security/tokens
com.onaro.sanscreen.acquisition.framework.datasource.DataSourceErrorException: Unable to login to the device. Error message received from device is : Request failed with status 401 : https://<opscenter_name>:20961/v1/security/tokens
at com.onaro.sanscreen.acquisition.datasource.hds_opscenter.transport.OpsCenterAdministratorRestClient.fetchSecurityTokenForOpsCenterAdministrator(OpsCenterAdministratorRestClient.java:70) ~[hds_opscenter.jar:?]
at com.onaro.sanscreen.acquisition.datasource.hds_opscenter.OpsCenterFoundationPackage.doTest(OpsCenterFoundationPackage.java:73) [hds_opscenter.jar:?]
at com.onaro.sanscreen.acquisition.foundation.datasource.BaseFoundationPackage.test(BaseFoundationPackage.java:301) [hds_opscenter.jar:?]
at com.onaro.sanscreen.acquisition.framework.datasource.BaseDataSource.test(BaseDataSource.java:817) [au.jar:?]
at com.onaro.sanscreen.acquisition.framework.datasource.BaseDataSource.test(BaseDataSource.java:744) [au.jar:?]
at com.onaro.sanscreen.acquisition.framework.mgmt.DataSourceManager$DataSourceTest.run(DataSourceManager.java:678) [au.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_333]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_333]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_333]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_333]
at java.lang.Thread.run(Thread.java:750) [?:1.8.0_333]
  • The same credentials when tried directly to access OpsCenter works fine
New to NetApp?
