NetApp Knowledge Base
Brocade portshow failed on Insight datasource
86
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
ds_dii
Last Updated:
Applies to
  • OnCommand Insight (Insight) 7.3.13
  • Brocade datasource
Issue
Portshow command failed with error on Insight Datasource:
20XX-01-02 00:31:41,290 WARN  [com.onaro.sanscreen.acquisition.datasource.brocade.builders.BrocadeAbstractBuilder] [foundation] stars_ant_fab_A - XX.X.XXX.XXX - Unable to parse portshow: Invalid hex FCID length: 4 (expected 6)
20XX-01-02 00:31:41,290 INFO  [com.onaro.sanscreen.acquisition.datasource.brocade.builders.BrocadeAbstractBuilder] [foundation] stars_ant_fab_A - XX.X.XXX.XXX - Attempting to execute portshow on single ports from port index: 0
20XX-01-02 00:31:43,228 FATAL [com.onaro.sanscreen.acquisition.framework.datasource.BaseDataSource] [foundation] stars_ant_fab_A - Runtime exception: Command failed: portshow
java.lang.RuntimeException: Command failed: portshow
Caused by: java.lang.IllegalArgumentException: Invalid hex FCID length: 4 (expected 6)
at com.onaro.sanscreen.acquisition.common.Fcid.toValue(Fcid.java:91) ~[brocade_cli.jar:?]
at com.onaro.sanscreen.acquisition.common.Fcid.<init>(Fcid.java:60) ~[brocade_cli.jar:?]
at com.onaro.sanscreen.acquisition.datasource.brocade.builders.BrocadePortBuilder.populateFromPortShowCommand
(BrocadePortBuilder.java:537) ~[brocade_cli.jar:?]
at com.onaro.sanscreen.acquisition.datasource.brocade.builders.BrocadePortBuilder.executeSinglePortShowCommand
(BrocadePortBuilder.java:722) ~[brocade
New to NetApp?
