NetApp Knowledge Base
AIQUM API triggers MetroCluster is not supported in ONTAP cluster audit log
96
Visibility:
Votes:
1
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
  • ONTAP 9.x
  • ActiveIQ Unified Manager (AIQUM) 9.10 and above
  • All OS versions
Issue
  • ONTAP cluster audit log shows MetroCluster is not supported error every 15 minutes
  • Error message:
GET /api/cluster/metrocluster/interconnects?fields=node,partner_type,adapter,state,type,mirror,interfaces
MetroCluster is not supported when HAOSC is not set to "mcc", "mcc-2n" or "mccip". Run the "ha-config modify chassis"
and "ha-config modify controller" commands in maintenance mode to change the HAOSC settings on node "<node>" in cluster "<cluster>"
  • The Remote IP address triggering the API call is AIQUM using the user used to authenticate the cluster on AIQUM
New to NetApp?
