How to create persistent static route on AIQUM OVA with multiple interfaces
Applies to
ActiveIQ Unified Manager (AIQUM) OVA
A user has 3 different interfaces.
eth0 is for communication with clusters
eth1 is for syslog server receiving snmp traps
eth2 is for accessing AIQUM from a different network.
The ask is to add a static route which will be persistent after reboot on eth1 so that the syslog server is reachable through a gateway on the network of where eth1 is connected.
Inserting static route in Maintenance console does not work as expected
Having multiple interfaces makes it more difficult
