NetApp Knowledge Base
CAIQUM-8548: Polling of CVOs fails due to efficiency state missing from API response for DP destination volumes
173
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
OM
Last Updated:
Issue
  • Monitoring of CVOs within Unified Manager fail
  • Error seen in the AU.log
2025-12-05 11:40:56,720 ERROR [common-pool-0] c.o.s.a.f.d.BaseDataSource (BaseDataSource.java:336) - [netappfoundation] <cluster name here> - Runtime exception: null java.lang.NullPointerException
    at com.onaro.sanscreen.acquisition.datasource.netapp_ocie.transform.ocie.NetAppOCIETransform.transformVolumeSisStatus(NetAppOCIETransform.java:2077) ~[au-datasource-netappfoundation.jar:9.16.0-2025.05.J22]
    at com.onaro.sanscreen.acquisition.datasource.netapp_ocie.transform.ocie.NetAppOCIETransform.transform(NetAppOCIETransform.java:199) ~[au-datasource-netappfoundation.jar:9.16.0-2025.05.J22]
    at com.onaro.sanscreen.acquisition.datasource.netapp_ocie.NetAppOCIEDataSource.doFoundation(NetAppOCIEDataSource.java:300) ~[au-datasource-netappfoundation.jar:9.16.0-2025.05.J22]
    at com.onaro.sanscreen.acquisition.netappfoundation.datasource.NetAppFoundationPackage.pollNow(NetAppFoundationPackage.java:199) ~[au-package-netappfoundation.jar:9.16.0-2025.05.J22]
    at com.onaro.sanscreen.acquisition.framework.datasource.BaseDataSource.run(BaseDataSource.java:269) ~[au-framework.jar:9.16.0-2025.05.J22]
    at com.onaro.sanscreen.acquisition.framework.mgmt.DataSourceManager$PollLogic.run(DataSourceManager.java:756) ~[au-framework.jar:9.16.0-2025.05.J22]
    at com.onaro.sanscreen.acquisition.framework.mgmt.scheduler.SchedulerTask.runLogic(SchedulerTask.java:102) ~[au-framework.jar:9.16.0-2025.05.J22]
    at com.onaro.sanscreen.acquisition.framework.mgmt.scheduler.Scheduler$LogicWrapper.run(Scheduler.java:271) ~[au-framework.jar:9.16.0-2025.05.J22]
    at com.onaro.commons.metrics.executor.ThreadPoolMonitorExecutor.lambda$submit$1(ThreadPoolMonitorExecutor.java:178) ~[commons-commons.jar:9.16.0-2025.05.J22]
    at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
    at java.util.concurrent.FutureTask.run(FutureTask.java:264) ~[?:?]
    at com.onaro.commons.metrics.executor.ThreadPoolMonitorExecutor.lambda$execute$0(ThreadPoolMonitorExecutor.java:164) ~[commons-commons.jar:9.16.0-2025.05.J22]
    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) ~[?:?]
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) ~[?:?]
    at java.lang.Thread.run(Thread.java:829) ~[?:?]
New to NetApp?
