NetApp Knowledge Base
CAIQUM-7956: Rediscover cluster is grayed out in AIQUM due to missing compression data in the REST API response
2,501
Visibility:
Votes:
1
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Issue
  • ONTAP is not returning compression data for some volumes via REST API when it is requested by AIQUM.
  • Error seen in au.log:
ERROR [common-pool-4897] c.o.s.a.d.n.b.r.g.n.GClusterBuilder (GClusterBuilder.java:251) - [netappfoundation] cluster.acme.com - ExecutionException encountered on Builder java.util.concurrent.ExecutionException: java.lang.NullPointerException: Cannot invoke "java.lang.Long.intValue()" because the return value of "org.json.simple.JSONObject.get(Object)" is null java.lang.NullPointerException:* Cannot invoke "java.lang.Long.intValue()"* because the return value of "org.json.simple.JSONObject.get(Object)" is null
    at com.onaro.sanscreen.acquisition.datasource.netapp_ocie.builders.rest.gmode.netappfoundation.GVolumeBuilder.buildModel(GVolumeBuilder.java:98) ~[au-datasource-netappfoundation.jar:9.18.0-2026.01.J68]
    at com.onaro.sanscreen.acquisition.datasource.netapp_ocie.builders.rest.gmode.netappfoundation.GVolumeBuilder.buildModel(GVolumeBuilder.java:38) ~[au-datasource-netappfoundation.jar:9.18.0-2026.01.J68]
  • You may also also see in the au.log
ERROR [common-pool-854] c.o.s.a.f.d.BaseDataSource (BaseDataSource.java:336) - [netappfoundation] cluster - Runtime exception: Cannot invoke "com.onaro.sanscreen.acquisition.datasource.netapp_ocie.model.EnumWrapper.getEnumValue()" because the return value of "com.onaro.sanscreen.acquisition.datasource.netapp_ocie.model.cmode.CModeSisStatus.getState()" is null java.lang.NullPointerException: Cannot invoke "com.onaro.sanscreen.acquisition.datasource.netapp_ocie.model.EnumWrapper.getEnumValue()" because the return value of "com.onaro.sanscreen.acquisition.datasource.netapp_ocie.model.cmode.CModeSisStatus.getState()" is null
  • This can lead to the cluster polling operation state getting stuck "In Progress" / "Failed"
New to NetApp?
