NetApp Knowledge Base
CAIQUM-6758: Incorrect hardware encryption status for a volume on an ADP enabled hardware
261
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Issue
  • Volumes in some aggregates show that hardware encryption is enabled in AIQUM
  • When the volume is moved to another aggregate, the hardware encryption status changes
  • Via System Manager or ONTAP CLI, it shown that hardware encryption is not used on either aggregate
  • ADP enabled hardware is in use
  • The aggregates are on different partitions across the same disks
  • REST collections are in use on AIQUM via the cloud agent component instead of ZAPI
New to NetApp?
