NetApp Knowledge Base
CAIQUM-6521: Acquisition fails with NumberFormatException when run through CLAG
1,053
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Issue
  • AIQUM acquisition of cluster fails intermittently/consistently
  • Cloud agent is enabled on AIQUM
  • AU.log shows:
ERROR [common-pool-1799] c.o.s.a.d.n.b.r.g.n.GClusterBuilder (GClusterBuilder.java:251) - [netappfoundation] Cluster-name - ExecutionException encountered on Builder java.util.concurrent.ExecutionException:
com.google.gson.JsonSyntaxException: java.lang.NumberFormatException: For input string: "2024-10-04T17:05:25+05:30" java.lang.NumberFormatException: For input string: "2024-10-04T17:05:25+05:30"
  at jdk.internal.math.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:2054) ~[?:?]
  at jdk.internal.math.FloatingDecimal.parseDouble(FloatingDecimal.java:110) ~[?:?]
  at java.lang.Double.parseDouble(Double.java:543) ~[?:?]
  at com.google.gson.stream.JsonReader.nextLong(JsonReader.java:963) ~[gson.jar:?]
  at com.google.gson.internal.bind.TypeAdapters$11.read(TypeAdapters.java:305) ~[gson.jar:?]
  at com.google.gson.internal.bind.TypeAdapters$11.read(TypeAdapters.java:297) ~[gson.jar:?]
  at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$1.read(ReflectiveTypeAdapterFactory.java:168) ~[gson.jar:?]
  at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:291) ~[gson.jar:?]
  at com.google.gson.Gson.fromJson(Gson.java:950) ~[gson.jar:?]
  at com.google.gson.Gson.fromJson(Gson.java:915) ~[gson.jar:?]
  at com.google.gson.Gson.fromJson(Gson.java:864) ~[gson.jar:?]
  at com.google.gson.Gson.fromJson(Gson.java:835) ~[gson.jar:?]
  at com.onaro.sanscreen.acquisition.datasource.netapp_ocie.builders.rest.gmode.netappfoundation.GVolumeMoveBuilder.buildModel(GVolumeMoveBuilder.java:64) ~[au-datasource-netappfoundation.jar:9.14.0-2024.04.J495]
  at com.onaro.sanscreen.acquisition.datasource.netapp_ocie.builders.rest.gmode.netappfoundation.GVolumeMoveBuilder.buildModel(GVolumeMoveBuilder.java:24) ~[au-datasource-netappfoundation.jar:9.14.0-2024.04.J495]
New to NetApp?
