NetApp Knowledge Base
CAIQUM-6159: Adding Cluster to AIQUM 9.14+ failing with exception if the cluster has SAML enabled
1,560
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
OM
Last Updated:
Issue
Adding, modifying, or removing a cluster in AIQUM fails when Security Assertion Markup Language (SAML) is enabled.
YYYY-MM-DD HH:MM:SS ERROR [SAML_user] [default task-3] [c.n.d.o.o.OntapMutualAuthenticationManager] Exception installing Mutual TLS certificate on ONTAP com.google.gson.JsonSyntaxException: com.google.gson.stream.MalformedJsonException: Use JsonReader.setLenient(true) to accept malformed JSON at line 1 column 13 path $
ERROR [umadmin] [default task-166] [c.n.d.o.o.OntapMutualAuthenticationManager] Exception installing Mutual TLS certificate on ONTAPcom.google.gson.JsonSyntaxException: com.google.gson.stream.MalformedJsonException: Use JsonReader.setLenient(true) to accept malformed JSON at line 1 column 13 path $
New to NetApp?
