NetApp Knowledge Base
CAIQUM-4712: Cluster operation state shows "failed" in AIQUM with PKIX path building failed
3,006
Visibility:
Votes:
3
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Issue
  • Cluster operation state shows failed in AIQUM
  • Rediscovering the cluster fails
  • Restore operations via AIQUM fails for the cluster
  • If a cluster is not successfully configured due to this problem, nothing is shown in the Dashboard
  • Events are not generated/Alerts not triggered due to failed acquisition
  • Intermittent cluster monitoring events are generated
  • Errors seen in the ocumserver.log:
    • Caused by: javax.net.ssl.SSLHandshakeException:PKIX path building failed:
      sun.security.provider.certpath.SunCertPathBuilderException:unable to find valid certification path to requested target
    • 2023-10-13 15:14:42,498 ERROR [oncommand] [reconciliation-2] [IP_or_HostName(incremental@15:14:39.135)] [c.n.dfm.collector.OcieJmsListener]Inventory change listener error
      java.lang.RuntimeException: com.ctc.wstx.exc.WstxUnexpectedCharException:Unexpected character '>' (code 62) expected '='
    • 2023-10-16 00:03:01,881 ERROR [oncommand] [reconciliation-3] [IP_or_HostName(incremental@00:02:57.421)] [c.n.dfm.collector.OcieJmsListener]Inventory change listener error
      java.lang.RuntimeException: com.ctc.wstx.exc.WstxUnexpectedCharException:Unexpected character '&' (code 38) (expected a name start character)
    • 2024-07-24 11:54:07,680 ERROR [oncommand] [reconciliation-3] [IP_or_HostName(incremental@11:54:00.218)] [c.n.dfm.collector.OcieJmsListener]Inventory change listener error
      java.lang.RuntimeException: com.ctc.wstx.exc.WstxParsingException:Duplicate attribute 'id'.
  • Additional messages seen in the au.log:
    • 2024-04-08 10:33:04,771 INFO  [foundation-poll-0] c.o.s.a.d.n.t.z.ZAPIConnection (ZAPIConnection.java:766) - Inside after checking mutual tls
New to NetApp?
