NetApp Knowledge Base
Unable to delete Restricted aggregate
143
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
ONTAP 9
Issue
  • Re-purposed disks still shows old root aggregate in restricted State.
  • System debug vreport show output of node reports:"Present in VLDB and WAFL
  • node not reachable"
  • Deleting the aggregate fails with the error
cluster::*> storage aggregate remove-stale-record -nodename Node-01 -aggregate aggr0_Node_01_root
Error: command failed: Failed to delete aggregate "aggr0_Node_01_root". Reason: aggregate 'aggr0_Node_01_root' cannot be destroyed because it is restricted. You will need to take it offline
before destroying it.
New to NetApp?
