NetApp Knowledge Base
Error: Command Failed - Failed to Delete Vserver
148
Visibility:
Votes:
0
Category:
snapmirror
Specialty:
dp
Last Updated:
Applies to
  • ONTAP 9
  • SVMDR (Storage Virtual Machine Disaster Recovery)
  • SnapMirror
Issue
Attempting to delete an SVM (Storage Virtual Machine) fails with the following error:
::*> vserver delete -vserver svm_uat_dest
Error: command failed: Failed to delete Vserver svm_ust_dest. Reason: Cannot delete Vserver "svm_ust_dest" because there are objects associated with the Vserver that are not associated with any other Vserver:
       Volumes: 1
       Mirrors: 1
       Kerberos-enabled LIFs: 0
       Object Stores: 0
       Remove these objects, then try the command again.
New to NetApp?
