Error: Command Failed - Failed to Delete Vserver
Applies to
- ONTAP 9
- SVMDR (Storage Virtual Machine Disaster Recovery)
- SnapMirror
Issue
Attempting to delete an SVM (Storage Virtual Machine) fails with the following error:
::*> vserver delete -vserver svm_uat_dest
Error: command failed: Failed to delete Vserver svm_ust_dest. Reason: Cannot delete Vserver "svm_ust_dest" because there are objects associated with the Vserver that are not associated with any other Vserver:
Volumes: 1
Mirrors: 1
Kerberos-enabled LIFs: 0
Object Stores: 0
Remove these objects, then try the command again.
