NetApp Knowledge Base
ASUP is not working after enabling OCSP
30
Visibility:
Internal
Votes:
0
Category:
not set
Specialty:
not set
Last Updated:
Applies to
  • * ONATP 9
  • * AutoSupport (ASUP)
  • * Active IQ Digitial Advisor
Issue
ASUP stops working with an error:
::> system node autosupport check show-details -check-type http*
Category: http- https
Component: http-put-destination
Status: failed
Detail: HTTP/S PUT connectivity check failed for destination:
https://support.netapp.com/put/AsupPut/. Error: Peer
certificate can not be authenticated with given
Certificate Authority certificates.. Failed to send OCSP
request to OCSP responder: host:"ocsp.sectigo.com",
port:"80", path:"/".
Corrective Action: Certificate issue. Please make sure you have the correct
Root Certificate installed
Component: http-post-destination
Status: failed
Detail: HTTP/S POST connectivity check failed for destination:
https://support.netapp.com/asupprod/post/1.0/postAsup.
Error: Peer certificate can not be authenticated with
given Certificate Authority certificates.. Failed to
send OCSP request to OCSP responder:
host:"ocsp.sectigo.com", port:"80", path:"/".
New to NetApp?
This is an internal KB article and its content should not be copy/pasted and shared with people outside of NetApp. Always seek Duty Manager authentication of caller for password reset requests. If you need further assistance post a question in Knowledge Xchange
