NetApp Knowledge Base
Node accessible via HA-IC, but cluster access failed during cluster switch migration
808
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
HW
Last Updated:
Applies to
  • Switchless cluster to BES-53248 cluster switch conversion
Issue
  • Following the below procedure to migrate from 2 node switchless cluster to switched cluster with BES-53248 cluster switches:
     Migrate to a switched NetApp cluster environment using Broadcom-supported BES-53248 cluster switches
  • Each node has e0a cluster port connected to new cluster switch cs1
  • The e0b cluster ports are still connected to each other
  • There is a link error (port flapping due to faulty cable) on one of the links connected to the new switch
  • The following is seen on the affected node:
cluster1::> storage failover show
                              Takeover
Node           Partner        Possible State Description
cluster1-01    cluster1-02    true     Connected to cluster1-02.
cluster1-02    cluster1-01    -        Up. Node accessible via HA-IC, but
  • Data may stop being served by this node or by indirect access to this node
New to NetApp?
