NetApp Knowledge Base
OpenStack: How to enable https with CA signed certs for Cinder
2,272
Visibility:
Votes:
7
Category:
openstack
Specialty:
virt
Last Updated:
Applies to
  • OpenStack
  • ONTAP
This article walks through how to enable https for Cinder volume backends by using CA signed certificates.  The environment this guide is based on is:
  • ONTAP 9.5
  • OpenStack Stein
  • OpenSSL CA (Certificate Authority)
Note: This procedure was tested where Openstack services are runing locally on the Openstack controller (a systemd deployment).  This procedure has not been tested where Openstack services are running in containers (such as with a kolla-ansible install) or in an environment using a floating or virtual IP address.
New to NetApp?
