NetApp Knowledge Base
Why does flex volume clone split take a long time?
3,574
Visibility:
Votes:
5
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
Answer
Clone-splitting is a copy operation that might take considerable time and resources to carry out due to the following reasons:
  • Free blocks in the aggregate are used to copy blocks shared between the parent and the clone
  • Clone-splitting incurs disk I/O operations, and can potentially compete with other disk operations in the aggregate
  • Clone-splitting uses some available CPU resources, which may impact the performance of a fully-loaded storage controller
  • The clone split operation runs in the background and priorities are set in such a way that it does not significantly impact foreground operations
  • Tiered data in the source volume is not tiered in the split-off volume and retrieving objects from cloud tier might take a significant amount of time
