NetApp Knowledge Base
Why Does NetApp Harvest Report High Usage Times for WAFL Cleaning?
1,557
Visibility:
Votes:
1
Category:
data-ontap-8
Specialty:
perf
Last Updated:
Applies to
  • ONTAP 9
  • NetApp Harvest
  • Clustered Data Ontap (CDOT)
Answer
  • The NetApp Harvest performance monitoring tool may report high system utilization for "WAFL Write Cleaning":
wafl_write_cleaning
  • "WAFL Write Cleaning" is NetApp Harvest's terminology for the time the controller spent processing Consistency Points (CP)
  • Consistency Points have several phases; WAFL Write Cleaning refers to a specific phase of the consistency point where metadata is gathered from disk
  • The presence of high system utilization due to WAFL Write Cleaning is not indicative of a performance problem; it is a completely normal performance state
Additional Information
Add your text here.
New to NetApp?
